Hi Johnny,
Jumper J2 should remain in shorting pins 1 and 2. This jumper was provided to allow the future possibility of High Speed 2.5V Low Voltage Differential outputs on JP5. But you should leave it shorting pins 1 and 2 to use it a General Purpose 3.3V I/O. See the picture here:
Jumper J3 is the Jumper to use USB power. But with both KFlop+Kanalog the current exceeds the 500ma max allowed by most USB ports. So you must remove J3 and apply external +5V either using the KFlop Molex connector JR1 or by applying it into a +5V screw terminal on Kanaog JP8.
Message: 739 |
Date: 10/31/2010 |
Subject: Re: What is the purpose of J2? |
Thanks!
> Hi Johnny,
> http://www.dynomotion.com/Help/SchematicsKFLOP/ConnectorsKFLOP.htm
> TKÂ
> From: nukeitout <nukeitout@...>
> Sent: Sun, October 31, 2010 2:16:47 PM
> Subject: [DynoMotion] What is the purpose of J2?
> I can't find any information on J2.
> I have a KFLOP mounted onto a KANALOG and I'm trying to power it with the usb
> connector. It should be possible from what I read.
> Please help.
> Thanks,
> Johnny
